shackles
- 1970F250
shackles
i stole the first picture from Thundercat6870. sorry .
i have these shackles on my truck. is it possible to take them off and replace them with a regular shackle like the one in the second link?
http://www.fordification.com/forum/download.php?id=2318
http://www.funddealernet.com/e350velvet ... ct0033.JPG
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
re: shackles
If you replace the springs as well. The spring setup used with the Flex-o-matic shackles are a different length than those used with the regular shackles. But why would you want to?
- 1970F250
- 460 crew
re: shackles
Fab up some of your own hangers or use the ones your talking about but call up Deaver springs if your interested in cost effective travel and not 3 or 4 linking. Just a thought, Deavers work fine as long as your not towing anything.
- boots
re: shackles
4 link would mean alot of $ and time...
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- boots
yes, yes it would1970F250 wrote:yeah but it would be really cool
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
re: shackles
Want the most cost effective solution?
Go get 2 90lb. bags of ready mix. Put them behind the wheelwells in
the bed.
the bed.
re: shackles
Naw, the back wheels will stay on the ground more!
re: shackles
Just try and remove a couple of leafs from the rear,its too stiff and when you land with softer springs the compression damping in the shocks will help keep the bounce down as will lower tire pressure.Make sure you retorque the rear spring U bolts ,I think its 75lbs.
- marz68
