shackles
1970F250
shackles
Post by 1970F250 »
i stole the first picture from Thundercat6870. sorry :evil:.
i have these shackles on my truck. is it possible to take them off and replace them with a regular shackle like the one in the second link?
http://www.fordification.com/forum/download.php?id=2318
http://www.funddealernet.com/e350velvet ... ct0033.JPG
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
re: shackles
If you replace the springs as well. The spring setup used with the Flex-o-matic shackles are a different length than those used with the regular shackles. But why would you want to?
1970F250
Post by 1970F250 »
wheel travel :D
i want to be able to use more than 4" of my giant shocks for when im in the air :evil:
maybe i should 4 link it.
Steve
460 crew
re: shackles
Post by 460 crew »
Fab up some of your own hangers or use the ones your talking about but call up Deaver springs if your interested in cost effective travel and not 3 or 4 linking. Just a thought, Deavers work fine as long as your not towing anything. :wink:
boots
re: shackles
Post by boots »
4 link would mean alot of $ and time...
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
1970F250
Post by 1970F250 »
yeah but it would be really cool :D
Steve
boots
Post by boots »
1970F250 wrote:yeah but it would be really cool :D
yes, yes it would :D
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
Jake11
re: shackles
Post by Jake11 »
Want the most cost effective solution?
Go get 2 90lb. bags of ready mix. Put them behind the wheelwells in
the bed. :)
yeah they are 3.00 a bag for quikcrete.
1970F250
Post by 1970F250 »
but that would make it sink when im off roading lol
Steve
Jake11
re: shackles
Post by Jake11 »
Naw, the back wheels will stay on the ground more! :)
dragtruck
re: shackles
Post by dragtruck »
Just try and remove a couple of leafs from the rear,its too stiff and when you land with softer springs the compression damping in the shocks will help keep the bounce down as will lower tire pressure.Make sure you retorque the rear spring U bolts ,I think its 75lbs.
marz68
Post by marz68 »
Just 4 link that sucker. :D
1970F250
Post by 1970F250 »
muahahahaha :evil:
Steve
spartman
Post by spartman »
Is that your rig Steve?
If so NICE!!!
