M/C losing fluid in front res.?
- prime mover
the small section of my master looks like its leaking out the top and pouring down the sides, what is causing this? I replaced it a couple months ago and did the front brakes, I didnt check the rears yet but I dont see any leaks at the rear backing plates.
72 F-350 crew cab, 59 mercury parklane, 64-1/2 mustang
- 68F250
re: M/C losing fluid in front res.?
Is the fluid level rising in the smaller reservoir? I had a problem like that when the mc was going out. It would push fluid from the larger reservoir to the smaller one and eventually overflow it.
Even when the mc was new, the cap would leak if you didn't have it on in just the right position. The rim of the mc made a dent on the cap gasket and you had to line up the rim with the dent. And the rim had to be absolutely clean of any surface corrosion. The wire holddown can also bend out and exert less pressure.
Barry
- Heavenlyfire
- 67effie
Make sure that there is no corrosion opn the seal itself. This will cause this problem also.
If at first you don't succeed. Get another beer.
Jeremy
1972 F-100 - currently under going complete frame off restoration
1997 Mustang GT Convertible- (gone but not forgotten, damn unemployment)
1996 Saleen S281 #247
1988 - Coupe, OSP car sold to public NEW, under construction, 1 of 3 that was supposed to go to Saleen in 1988.
http://www.fordification.com/galleries/ ... ?album=270
Jeremy
