What can I do w/ my suspension? (upgrades, replace...)
I have a 71 F100 Custom 2wd 302, no power steering/brakes. I was just wondering what I can/should replace in my suspension for a safer, smoother ride. Everything on it right now is stock from 71 except for new tires/rims. Any suggestions on what brands are better quality/performance.
Thanks!
- old_mare
Re: What can I do w/ my suspension? (upgrades, replace...)
Check the front end- all the steering components for any looseness; look at the springs, make sure there are none broken.
Other than that, make sure everything's all greased up and if it ain't broke, don't fix it!
hth,
-JT-
hth,
-JT-
"I'm a man, and I can change, if I have to, I guess." -Red Green
I'd rather push a Ford than drive a Chevy!
1930 Tudor : 1930 Pickup : 1969 F250 Custom
- mrtleavitt
check radius arm bushings king pins coil and leaf springs. as well as shocks. for a safer ride also check all the drag link and tie rod studs for wear.
