mlheppl
Posts: 564 Joined: Mon Nov 23, 2009 1:43 pm
Post
by mlheppl » Thu Mar 18, 2010 2:38 pm
I know that the 2wd's have a rag joint, but my highboy has this part instead. What is the correct or even common name for this part?
TIA
Mike
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
Posts: 22329 Joined: Sun Aug 28, 2005 8:17 pm
Post
by fordman » Thu Mar 18, 2010 4:05 pm
i called the whole thign a steerign shaft. i dont know what the joint is called.
hazelnut
Posts: 1928 Joined: Fri Oct 23, 2009 1:06 am
Post
by hazelnut » Fri Mar 19, 2010 12:51 am
i dont know what its called but isnt there somekind of bushing inside of it for the pin on the steering shaft, i have the same on my truck and somehow the bushing got lost when i had my truck apart and now ive got 2" of play in my steering wheel. guess im going to have to make a bushing for it or something.
fmartin_gila1
Posts: 284 Joined: Wed Jul 25, 2007 9:20 am
Post
by fmartin_gila1 » Fri Mar 19, 2010 2:40 am
That is called 'Ball & Trunion' Universal Joint.
Fred
convincor
Posts: 1511 Joined: Wed Sep 12, 2007 5:05 am
Post
by convincor » Fri Mar 19, 2010 1:30 pm
mlheppl
Post
by mlheppl » Fri Mar 19, 2010 1:31 pm
That's what I did. replaced it with a regular u-joint. For some reason it was really bugging me that I didn't know what it was called.
Mike
71 F250 4X4
Post
by fordman » Fri Mar 19, 2010 2:47 pm
i actually found one of those on a 79 4wd. i still have it here. you can also find them on chevy trucks.
averagef250
Posts: 4387 Joined: Fri Mar 17, 2006 12:58 am
Post
by averagef250 » Fri Mar 19, 2010 7:39 pm
You can't replace it with a regular U-joint. If you do any bump will blow the bearings out of your steering column. There needs to be a slip or a rag joint in the shaft.
convincor
Post
by convincor » Fri Mar 19, 2010 7:57 pm
good point.
the Borgeson listed above are "Telescoping".
mlheppl
Post
by mlheppl » Sat Mar 20, 2010 11:41 am
Thanks for the tips guys.
Mike
71 F250 4X4
mlheppl
Post
by mlheppl » Sat Mar 20, 2010 12:18 pm
averagef250 wrote: You can't replace it with a regular U-joint. If you do any bump will blow the bearings out of your steering column. There needs to be a slip or a rag joint in the shaft.
Will installing a u-joint with a vibration dampner work?
Mike
71 F250 4X4
convincor
Post
by convincor » Sat Mar 20, 2010 1:39 pm
there needs to be a slip or rag joint somewhere.
