What's the correct name for this part?
mlheppl
Post by mlheppl »
I know that the 2wd's have a rag joint, but my highboy has this part instead. What is the correct or even common name for this part?
TIA
Mike
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
Re: What's the correct name for this part?
i called the whole thign a steerign shaft. i dont know what the joint is called.
hazelnut
Post by hazelnut »
i dont know what its called but isnt there somekind of bushing inside of it for the pin on the steering shaft, i have the same on my truck and somehow the bushing got lost when i had my truck apart and now ive got 2" of play in my steering wheel. guess im going to have to make a bushing for it or something.
fmartin_gila1
Post by fmartin_gila1 »
That is called 'Ball & Trunion' Universal Joint.
Fred
convincor
Post by convincor »
here's the exploded view with #'s.
This came up before and the is someone out there that has parts for it.
http://www.fordification.com/tech/image ... column.jpg
My self I would just replace with the regular u-joint.
"Still Plays With Trucks"
convincor
Post by convincor »
They also do mae a replacement shaft.
with damper or with out.
http://www.summitracing.com/parts/BRG-000970/
http://www.summitracing.com/parts/BRG-000975/
mlheppl
Post by mlheppl »
convincor wrote:here's the exploded view with #'s.
That's what I did. replaced it with a regular u-joint. For some reason it was really bugging me that I didn't know what it was called. :dk:
Mike
71 F250 4X4
convincor
Post by convincor »
it was called a steering coupler.
Number Dummy over of FTE found a guy that had parts for it i think.
:oops: sorry to do this but- http://www.ford-trucks.com/forums/87052 ... embly.html
i actually found one of those on a 79 4wd. i still have it here. you can also find them on chevy trucks.
averagef250
Post by averagef250 »
You can't replace it with a regular U-joint. If you do any bump will blow the bearings out of your steering column. There needs to be a slip or a rag joint in the shaft.
convincor
Post by convincor »
good point.
the Borgeson listed above are "Telescoping".
mlheppl
Post by mlheppl »
Thanks for the tips guys.
Mike
71 F250 4X4
mlheppl
Post by mlheppl »
averagef250 wrote:You can't replace it with a regular U-joint. If you do any bump will blow the bearings out of your steering column. There needs to be a slip or a rag joint in the shaft.
Will installing a u-joint with a vibration dampner work?
Mike
71 F250 4X4
convincor
Post by convincor »
there needs to be a slip or rag joint somewhere.
