Tie Rod Ends
91Bear
Tie Rod Ends
Post by 91Bear »
Advance Auto has this tie rod end listed for a 4WD, but nothing for a 2WD. Were the same tie rod ends used on both?
http://shop.advanceautoparts.com/webapp ... 5103720___
cep62
Re: Tie Rod Ends
Post by cep62 »
According to my Carquest site 2wd and 4wd are different.
I didn't have the year so i guessed at '69 judging by your picture.
91Bear
Re: Tie Rod Ends
Post by 91Bear »
Yes, sorry, 1969 2WD 302 cid.
Re: Tie Rod Ends
they are probably different because the 4wd has a axle under it and the 2wd just has i beams and spindles. althought the 4wd axle has spindles they are probably different because it is eithe r a dana 44 or dana 60 front axle in these trucks. depending on F100 d44 and F250 d60.
oh and how can you search the carquest website fo rparts. i have never figured that out.
cep62
Re: Tie Rod Ends
Post by cep62 »
fordman wrote:oh and how can you search the carquest website fo rparts. i have never figured that out.
We have web link at work so we can look up and order parts.
I tried to look up your exhaust parts but they didn't go back that far.
If you call them they might be able to go through some books .
Re: Tie Rod Ends
no i havent looked on thier for exhaust parts. we have a store 30 miles from here. its just i have tried to use them in the past with no link to actually look up parts.
91Bear
Re: Tie Rod Ends
Post by 91Bear »
The price for the drag link, inner and outer tie rod ends (Moog) is about $250. Is that excessive? Is it usually best to replace all three at the same time?
(I have lot of play in the steering and I doubt the tie rod ends on my 40 year old truck (140K miles) have ever been replaced.
BobbyFord
Re: Tie Rod Ends
Post by BobbyFord »
Check the steering coupler also if your steering is real sloppy. Have someone wiggle the steering wheel back and forth while you crawl around and research the slop.
ToughOldFord
Re: Tie Rod Ends
Post by ToughOldFord »
Autozone's website shows them for a total of $162.
I 2ond diagnosing it first though, it may just be the rag joint. You don't want to throw parts at it just for giggles unless you have money burning a hole in your pocket. :wink:
knightfire83
Re: Tie Rod Ends
Post by knightfire83 »
Check out http://www.rockauto.com/
Think you may save some $$ there. :2cents:
1970 Ford F250 4x4 ~ Sold.
