Suggest a good oil additive?
HH Henderson
Post by HH Henderson »
When my 360 is cool the oil light stays off, but after engine gets hot, the oil light comes on at idle speed. Sometimes it will not go off until I have built up a few rpms. In order to put new oil pump on, the engine will have to be removed. So if I could find a good proven additive, I will put it in and worry about changing oil pump later. Any Suggestion? :thup:
HH
"any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves Einstein
http://www.satisfaction.com/photobucket-login/
1968 Ford F100 360 cu (ole blue)
SteveC
re: Suggest a good oil additive?
Post by SteveC »
my 351w in my ltd does that what weight of oil are you using??
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
binder56jd
Post by binder56jd »
my 1st suggestion is to get aftermarket oil pressure gauge- i prefer the mechanical type--plumb it in and see what u have for a reading.
i look for a steady needle
high pressure reading are not really the thing you are looking for--steady pressure is-- it will be low after warm up--i ain't really an fe guy but a steady needle is what i look for except with ihc's-they flucuate at idle but hold steady at anything above--302 and 351 hold 20 pretty good at idle and 40-50 at run rpm
as far as additives go-there are 2 i will swear by
MOA by bg products for slickery
restore for getting additional miles from worn engines
lucas is ok for increasing viscosity but has a low friction factor(bearing burn)
now serving #235
HH Henderson
I m using 10w-30 Penz Oil. Thanks to each of you for the info. I ll give it a try. Have a good Ford Day.
HH :fr:
BobbyFord
Post by BobbyFord »
A lot of the stock 360 oil pumps were aluminum bodied and with time, would wear, increasing pump clearance tolerances, lowering oil pressure.
HH Henderson
I bet that is my problem. Engine has never been out of truck. Has about 125,000 on it. Thanks for info.
HH :)
You can change the pump with the engine in the truck...
It is a massive pain in the rear, but you can do it...
BobbyFord
Post by BobbyFord »
Also, if you yank the engine to do the pan (which is the best way to do it) make sure you replace the old rope rear main seal with a new two-piece rubber rear main. Toss a new converter seal in while you're at it.
binder56jd
BobbyFord wrote:Also, if you yank the engine to do the pan (which is the best way to do it) make sure you replace the old rope rear main seal with a new two-piece rubber rear main. Toss a new converter seal in while you're at it.
Bobby is right, but it made me laugh due to the "well, while i'm here" factor/syndrome :lol: :lol:
if ya got 'er out u just as well rebuild it :wink:
just ask Tony(wt4speed) :evil:
now serving #235
price2757
Post by price2757 »
U can also try a heavier oil. My DD was doing that until I went to 20-50 high mileage oil.
oldschoolrods
Re: re: Suggest a good oil additive?
Post by oldschoolrods »
price2757 wrote:U can also try a heavier oil. My DD was doing that until I went to 20-50 high mileage oil.
That is a good way to tell if the pump is going bad or if you have worn bearings, if the bearing clearance is too big the heavier oil will bring your pressure back.
clemm17
Post by clemm17 »
There is no magic snake oil that will cure a mechanical problem. I used power punch once and became an absoutle believer in power punch. I have ran it in in gearboxes and old engines and used properly it is a good addititve. I dumped a quart in a cleavend that was using so much oil I could hardly get to the next town, and I was on a bussiness trip. The guy told me to pour it in slow with engine ideling. What a differance it made. The whole engine changed. Lifters quited down,engine gained about 300 rpm. Oil consumtion was cut at least in half. This engine didnt really have any problems other than leaks but it I noticed a deffinate improvement after the power punch.
I have never tried it but I have also heard good things about restore and slick 50.
binder56jd
i have never heard of power punch
looked up on the net
http://www.powerpunch.biz/
i will have to try some--i have the perfect engine to give it a try
thanks clemm
now serving #235
HH Henderson
I think I will try the power punch as a beginner and if that does not work....When I pull the engine, I will just overhaul the sucker.
Got to get my power steering on first.
Thanks for all the input.
HH
cathynkeith
Post by cathynkeith »
I like Restore, on old engines I use it every oil change.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
