My bleader thing is striped
I can't get it off any suggestions much appreciated. It is on the 71 I bought yesterday no power brakes. I think that since the master cyclendar is still full after driveing for 3 miles that the brakes just need to be bled but can't do it with the bleeder nut stripped.
1972 F100 Ranger
1971 F100 Custom
1999 ford contour(what a great $400 car)
1982 Ford Minibus
1971 F100 Custom
1982 Ford Minibus
re: My bleader thing is striped
Well, it just means it's time to get a pair of Vise-grips on the bleeder and twist it out....which of course means you'll have to replace it.
that didn't fair too well for me I still can't get it off. I even used cheater bars to clamp it, its stuck like chuck dang that PO
1972 F100 Ranger
1971 F100 Custom
1982 Ford Minibus
1971 F100 Custom
1982 Ford Minibus
Well then, considering that the brake cylinder the bleeder valve threads into is only about $10-$12, I'd suggest just replacing it.
That sounds like a plan. On another note I am sorry to hear your losing the shop I hope you find a beauty of a home with 10 acres and a 5 car shop for a steal.
1972 F100 Ranger
1971 F100 Custom
1982 Ford Minibus
1971 F100 Custom
1982 Ford Minibus
Re: re: My bleader thing is striped
Yup, replace it, its easy. Have you tried some penetrating lube yet? I just went thru this a few months ago. One came loose, one came off with the cylinder and was replaced.FORDification wrote:Well then, considering that the brake cylinder the bleeder valve threads into is only about $10-$12, I'd suggest just replacing it.
- kaptnkaos
You could break or cut the head of the bleeder screw off and use an ez-out to get it out...
Or just do like Keith said and replace the cylinder itself...
KaptnKA
S
KaptnKA
