ignition switch
71 LONG BED
ignition switch
Post by 71 LONG BED »
When I bought my '67 F350 it had the key tumbler removed. A screw driver was needed to start it up. Here's what it looks like.
I was cleaning all of the junk off the floor (old seat belts, box of manifolt gaskets, new e-brake cable for a VW rabbit, gloves, etc) and look what I found!
I though to myself,"Awesome, now I wish I had the key." Well, look what I found next!!
Maybe this after noon I'll put it back in. A little cold out there right now. I wonder why it was removed. :dk:
John Member #1549
Image Image Image
ezernut9mm
re: ignition switch
Post by ezernut9mm »
man, i love that kind of stuff. i didn't find anything interesting when i bought my bump.
jor
re: ignition switch
Post by jor »
When the ignition switch went south, the previous owner probably went out and bought a Chevy. I'm betting he financed it through GMAC.
jor
Sharkdance
re: ignition switch
Post by Sharkdance »
They took the lock cylinder out because they thought the switch went bad. Instead they found a rats nest wiring harness and had to wire in the universal turn signal currently mounted on the column. Then they lost the key cylinder while starting it with a screwdriver. Then they lost the key while looking for the lock cylinder. :lol:
Sharkdance
70 F250 2WD 360/C6
71 LONG BED
re: ignition switch
:lolprev: :lolprev:
I've seen a thread on how to take the barrel out, I just don't know how to line it up to go back in. Does anyone know what to line up? I quickly tried to line it up and couldn't. I don't want to mess anything up by forcing it.
John Member #1549
Image Image Image
Sharkdance
re: ignition switch
Use the screwdriver to turn the switch to the accessory position. (all the way to the left)
Then, with the key in the lock cylinder line up the square slot in the switch with the square notch on the cylinder and push/wiggle/twist until it clicks into place.
Sharkdance
70 F250 2WD 360/C6
71 LONG BED
re: ignition switch
Thank you! Even though it's only 17* out, I may venture out for 5 minutes to try that. :D
John Member #1549
Image Image Image
71 LONG BED
re: ignition switch
Thanks Sharkdance! I was outside for maybe half a cup of coffee, or should I say about 5 minutes. It went in just like you said. :thup:
John Member #1549
Image Image Image
theskytoucher
re: ignition switch
Post by theskytoucher »
BUt did it start the truck?
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
yea did it work? it should have as long as the keys were correct for the cylinder.
71 LONG BED
re: ignition switch
The battery is dead. I have been taking the one out of the '71 to move it around. The key did seem to work. I was able to turn it to the start possision and to the acc. possion as well. :thup:
John Member #1549
Image Image Image
dcbullet
Post by dcbullet »
That's pretty cool you foudn that! I must not have been cleaned in a while....
rjewkes
Post by rjewkes »
My bump came with 2 sheets of sheetmetal. to probably fix the bed floor.
fuelly.com
