When I bought my '67 F350 it had the key tumbler removed. A screw driver was needed to start it up. Here's what it looks like.
I was cleaning all of the junk off the floor (old seat belts, box of manifolt gaskets, new e-brake cable for a VW rabbit, gloves, etc) and look what I found!
I though to myself,"Awesome, now I wish I had the key." Well, look what I found next!!
Maybe this after noon I'll put it back in. A little cold out there right now. I wonder why it was removed.
John Member #1549 71 F100 Sport Custom__________1967 F350 Gone, but not forgotten
They took the lock cylinder out because they thought the switch went bad. Instead they found a rats nest wiring harness and had to wire in the universal turn signal currently mounted on the column. Then they lost the key cylinder while starting it with a screwdriver. Then they lost the key while looking for the lock cylinder.
I've seen a thread on how to take the barrel out, I just don't know how to line it up to go back in. Does anyone know what to line up? I quickly tried to line it up and couldn't. I don't want to mess anything up by forcing it.
Use the screwdriver to turn the switch to the accessory position. (all the way to the left)
Then, with the key in the lock cylinder line up the square slot in the switch with the square notch on the cylinder and push/wiggle/twist until it clicks into place.
The battery is dead. I have been taking the one out of the '71 to move it around. The key did seem to work. I was able to turn it to the start possision and to the acc. possion as well.
My bump came with 2 sheets of sheetmetal. to probably fix the bed floor.
