Volt Meter Hook Up?
- cghstrojan08
Volt Meter Hook Up?
How do I hook a volt meter up? There is a +, -, and S. Thanks
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- cghstrojan08
re: Volt Meter Hook Up?
It is a gauge that you install to tell wether or not if the car is charging or discharging. Every car has one but I just want to put another one in my truck. It is a volt gauge. Not amp.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
Hook the red wire up to the 12v ignition switch and the other to a ground. Pretty much any 12v wire would give you system voltage. However, you want an ignition-switched wire so the gauge powers on when the keys are turned to the ON position.
For the lights run the wire(s) to a dash light source (ie. ashtray light) and the black to ground. Now they dim with the headlamp switch.
It's that easy.
It's that easy.
- cghstrojan08
What is the spot for the "S" wire?
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
I don't recall specifically...did you try the manufacturer's website? Normally they'll have installation instructions there.
- cghstrojan08
I found this in a junk yard. Can't find anything on the internet
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- cghstrojan08
There are seperate wires for the light.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- cghstrojan08
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
That's still a very common voltmeter sold everywhere. From the manufacturer's website:
http://www.iequus.com/downloads/manuals ... 0.revB.pdf
The lighting connection is obvious, so apparently the 'S' isn't needed. Maybe it's for calibration? Regardless, if you hook up the two wires as indicated and the lighting wire, you're all set.
S for set. It's postion on the guages is at the needles pivot the most common place on gauges for an adjustment screw.
The picture solved all.
