Volt Meter Hook Up?
cghstrojan08
Volt Meter Hook Up?
Post by cghstrojan08 »
How do I hook a volt meter up? There is a +, -, and S. Thanks
ROBERT
Member #1076
1968 F100 SWB 360
an amp guage or a test volt meter?
cghstrojan08
re: Volt Meter Hook Up?
It is a gauge that you install to tell wether or not if the car is charging or discharging. Every car has one but I just want to put another one in my truck. It is a volt gauge. Not amp.
ROBERT
Member #1076
1968 F100 SWB 360
Hook the red wire up to the 12v ignition switch and the other to a ground. Pretty much any 12v wire would give you system voltage. However, you want an ignition-switched wire so the gauge powers on when the keys are turned to the ON position.
For the lights run the wire(s) to a dash light source (ie. ashtray light) and the black to ground. Now they dim with the headlamp switch.
It's that easy. :D
cghstrojan08
What is the spot for the "S" wire?
ROBERT
Member #1076
1968 F100 SWB 360
I don't recall specifically...did you try the manufacturer's website? Normally they'll have installation instructions there.
cghstrojan08
I found this in a junk yard. Can't find anything on the internet
ROBERT
Member #1076
1968 F100 SWB 360
kid
Post by kid »
Don't hook it up the guage should still read okay. I bet S is the light terminal. Make the guage work first then see if S is jumped to + that the light works.
cghstrojan08
There are seperate wires for the light.
ROBERT
Member #1076
1968 F100 SWB 360
kid
Post by kid »
That is weird then S for Sense ? But a voltmeter takes the full voltage across it but almost no current so Sense does not make sense.
post a pic of the guage and wiring.
cghstrojan08
ROBERT
Member #1076
1968 F100 SWB 360
That's still a very common voltmeter sold everywhere. From the manufacturer's website:
http://www.iequus.com/downloads/manuals ... 0.revB.pdf
The lighting connection is obvious, so apparently the 'S' isn't needed. Maybe it's for calibration? Regardless, if you hook up the two wires as indicated and the lighting wire, you're all set.
kid
Post by kid »
S for set. It's postion on the guages is at the needles pivot the most common place on gauges for an adjustment screw.
The picture solved all.
