Front drums
gramsay
Front drums
Post by gramsay »
I ordered new front drums for my 2 wheel drive 1967 ford f100 and when they came they where the drums for the back and the guy claims that they are for the front. Does anyone have a picture of a front drum that I can show him?
i think i heard that the front drum comes off of the front hub. so it could be you have the right thing but there is a difference in how they look. i don't have any pics though. maybe there are some in the photo galleries or the project updates. maybe kisth has some pics in his first few pages of his project but i don't remember seeing any in there.
kknip
re: Front drums
Post by kknip »
Yea,I think the drums actually can be removed from the hub,but I've never tried.I think the front drums are a little wider than the back,but I'm not sure about that either. :?
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
FoMoCo
re: Front drums
Post by FoMoCo »
The Front drums are about 3/4 inches wider IIRC.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
67heavystepside
re: Front drums
Post by 67heavystepside »
my 67 f250 2wd the drum does come off the hub. there are or were 2 or 3 flat blade screws holding the drum to the hub, i still have the oe screws on mine. but the front drums do look similar to the rears.
re: Front drums
i got some pics for you the first one is from a 69 and the second is from a 70 both f100. you can see the groove in the one for the 69 the 70 drum doesn't have that groove.
Jake11
re: Front drums
Post by Jake11 »
Most times you have to knock the pressed in wheel studs out to get the
drums off the hub. Press/hammer&brass drift. Goes together the same way. Then they need to be turned.
mrung0wa
Post by mrung0wa »
FYI: Make sure that the studs aren't swaged.
They shouldn't be but it would be a good thing to check for if you having a rough time separating them apart.
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
flyboy2610
re: Front drums
Post by flyboy2610 »
If you want to be able to get the drums off easily next time, ream out the stud holes a little until they are just a hair bigger than the studs. The you can slip the drum over the studs and not have to have it pressed on.
mrung0wa
Post by mrung0wa »
Hey, isn't that cheating! :eek:
Lawrence :P
flyboy2610
Not if you get away with it! :wink:
bluef250
Post by bluef250 »
For what is worth, LMC lists the following parts -front drum 45-3952 and rear drum 45-3970. Looks like the rear drum was used for 20 years!!
