5 Speed for 410 FE
- HOWDY69
5 Speed for 410 FE
I am thinking about puting a 5 speed manual behind my 410FE. Does anyone have this setup with a 390/410/428? My C6 needs a rebuild and I would like better gas mileage.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
- customcrewcab
how about adding this
http://cgi.ebay.com/ebaymotors/gear-ven ... enameZWDVW
stock 5 speeds are not super strong and an adaptor kit could cost alot.
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
- customcrewcab
all c6's are the same except for the bellhousings. i am not sure but i think most gearvenders will bolt up to ant standard automatic transmission with the right brakets. i would check the part numbers, email the guy and look for some info on the web. i like standard transimiison but woudl like to have a gv if i have an automatic. i bought a 6 speed for my truck but i have a stroked 351 w. not sure if they have them for 6 speeds but i do know thay have them for 460's. ddperformance is where i got mine.
