I am searching for the spring that goes on the brake pedal to hold it up. or I beleive thats what I need. I have to put somthing under the pedal to keep it up otherwise the brake lights will stay on.
I tried seeing if some auto parts places would have it but no luck.
thanks
brake pedal spring?
- 72fordjah
- rjewkes
Theres no spring. How is your pedal pressure? Try bleeding that thing if that don't work replace the wheel cylinders and the master cylinder.
fuelly.com
fuelly.com
- splavin90
re: brake pedal spring?
if your pedal isn't returning sounds to me like a bad brake booster...
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
- 72fordjah
no it returns fine. its somthing to do with the brake light sensor, its all taped up on there. how is the sensor suppose to mount. I really hate not having a book for this truck.
- flyboy2610
My truck had an 'add on' spring that looked like it came from the hardware store. If you need a spring you'll have to fabricate something.
- turbocharged400sbc
Re: re: brake pedal spring?
ditto, i had the same issue on my 68, completly rebuilt the brakes and wheel cylinders etc and no matter what the brake lights would come on, i got a new switch as well and did all i could to adjust it but the adjustment for cold brakes and warm brakes...was enough to drive me mad...sooo...i got a spring for a small gate (think picket fence type) and threw it on there, no more problems, and only a slight increase in pedal effortflyboy2610 wrote:My truck had an 'add on' spring that looked like it came from the hardware store. If you need a spring you'll have to fabricate something.
problem solved, sanity kinda retained
regards, James
1994 Olds 442 (425 cid-4 wheel drive-2 V6's) http://www.cardomain.com/id/94twinengine442 13.81 @ 98.2 MPH 1.9s 60's
68 F250 Camper Special 390FE/NP435/3.73D60
soon: 79 F350 disk brakes w/ 3.55 D60, pneumatic, 1750w AC inverter, Vector 1600w lightbar, 200A 3g alt, all a mobile gearhead needs
- 72fordjah
thanks so much I bought the new sensor or switch and put it in. it works great! its on a 71 f100 btw.
I saw what kind of switch it was after i took all the ghetto electrical tape the previous owner had put on it. I also think he was an old drunk and ran off the side of the road and side swiped a tree. why my front right fender is wrecked.
