yeah but i dont want to remove the whole front clip. mainly since the rad support mounts/bushings are soo hard to remove. well atleast they were on my 100% rust free 69. if cut off grinder doesnt work ill probably start taking the front edn apartmljjones67 wrote:Can you pull the engine and trans out together?
how would you remove this nut?
- 1971ford
-Ryan
- convincor
Yep. but i'd still get it apart.1971ford wrote: take the tranny cross member out and then tilt ithe engine/tranny like crazy?
"Still Plays With Trucks"
- Redcap
- sideoilerfe
re: how would you remove this nut?
Shouldn't the torque converter just slide out of the transmission attached to the engine?
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- 390F100
When I removed the 390 and c6 out of the 70 f100 I took it all out together and it came out fine and was very easy to do, however I did have the same problem with the torque converter nuts being stuck on and stripping so what I did was use a chizel and be very careful to split the nut in half like stated above. The torque converter will slide out but I was informed that it could damage the torque converter if done so I ended up having to break the nuts. It sucked but it did work.
When I had that happen to me, I pounded a metric socket on there and got it broke loose that way. I think I used a 14 MM.
- sideoilerfe
Wow. Seems to be a popular problem. I guess I got lucky on mine.
- 1971ford
what do you guys think... necklace?
took an hour of constant gripping it with vise-grips as hard as i could and stripping it as much as i could. then i decided to try the hand massager (this is what i call the air-chissel sicne its a HF pos
) and i kept diging a hole in the side with it until i saw it actually twist
at that awsome moment i grabbed the vicegrips and twisted it off
and then i found one more nut on the flywheel that was allready starting to be stripped so i got a 14mm socket like suggested and bashed it on and off it came
not only that but i pulled the eninge
-Ryan
Re: re: how would you remove this nut?
It wont damage the torque converter on the way out you'll just make a giant mess when the converter drains on the shop floor, but if you try to put it back together that way it will damage the transmission pump.390F100 wrote:When I removed the 390 and c6 out of the 70 f100 I took it all out together and it came out fine and was very easy to do, however I did have the same problem with the torque converter nuts being stuck on and stripping so what I did was use a chizel and be very careful to split the nut in half like stated above. The torque converter will slide out but I was informed that it could damage the torque converter if done so I ended up having to break the nuts. It sucked but it did work.
BTW, congats Ryan
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
'72 crew 4x4
'07 KTM 450 xcw
- 390F100
Yea it was something like that, I have never had good luck with the Ford C6 even though they are just about bullet proof. I figure mine will be out and replaced with a TCI in about 6 months. Good luck with the project.
- willowbilly3
Yup, that. I use my die grinders all the time and what used to be "issues" really aren't anymore.convincor wrote:cut both sides of the nut off with a die grinder/cut-off wheel(without hitting the stud). Then hit the right side of the flat you made with a chisel. Should split right off. The nuts only aluminum...
Ryan, first off loose the 12 point sockets, and then next time you do have a bad nut, before you reach for the vicegrips, which will indiscriminately destroy anything you clamp them onto, try going to the next size smaller metric 6 point socket and drive it on with a bfh. Sometimes that works. So if the nut was a 9/16 then you would use a 14mm.
Keep at it kid, your doing great, good to see young'uns learning and doing stuff.
Oh, and I also have SK sockets that are like halfway between short and deep, fit just right in those places and I would be lost without them.
- FLATBEDFORD
I have almost always had good results with those too.CO684X4 wrote:These work great. I use them all the time at work. Just tap them on with a hammer and then use a socket and remove the nut.
http://www.sears.com/shc/s/p_10153_1260 ... s+%26+Dies
Steve
My Photo Gallery
My Photo Gallery
- LUB69F100
I guess my theory of "it takes a good wench to loosen a tight nut" is kinda moot now.
I'll shush
Lub
I'll shush
Lub
Remember, when someone annoys you, it takes 42 muscles in your face to frown. BUT it only takes 4 muscles to extend your arm and smack the idiot upside the head.
I child-proofed my house.....but they STILL get in!
