it is now stripped, and it is so tight on there its like its welded. havent gotten it to budge at all. you can see that i have gotten a very tight lock on it with vice-grips by the indentations on the nut. but still, it didnt budge. instead it just repeatedly sends me knuckles into the bellhousing.
ive tried removing that exhaust pipe, but the nuts of the exhaust pipe connecter are giving me the same problems.
its the only thing holding the engine in.
1971 Ford,
Can you fit a nut splitter in there? Or you could go to Harbour freight and get one of the Torch Pens for a couple of bucks and it will give you a flame like a torch for about 30 seconds to a minute to heat it up and break it loose. just my thoughts and
Semperfi,
Marine6212
We all came together, both young and old.
To fight for our freedom, to stand and be bold.
In the midst of all evil, we stand our ground.
And we protect our country from all terror around. Peace and not war, is what some people say. But I'll give my life, so you can live the American way. I give you the right to talk of your peace. To stand in your groups, and protest in our streets. But still I fight on, I don't bitch, I don't whine.
cut both sides of the nut off with a die grinder/cut-off wheel(without hitting the stud). Then hit the right side of the flat you made with a chisel. Should split right off. The nuts only aluminum...
convincor wrote:cut both sides of the nut off with a die grinder/cut-off wheel(without hitting the stud). Then hit the right side of the flat you made with a chisel. Should split right off.
sounds good, a cut off wheel wouldnt light the grease on fire or anything? that could get exciting really quick
Just keep a fire extinguisher handy! Seriously if you can't get to it just see if you can borrow an oxy-acetylene torch set from work (if they have them) and get that nut cherry red, then use the vise grips. It'll come off. I have a small portable set for soldering a/c lines on my work van that I've used a number of times on my jeep. Just watch for things you could catch on fire, it's approximately a 6000 degree flame
ON SECOND THOUGHT, there is a torque converter full of oil on the other side of that nut. Maybe the nut splitter would be a better idea...
ALTHOUGH, the flywheel will make a pretty good heat shield. Decisions decisions...
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
Hmmm....I recently had to deal with this exact same scenario:
I basically just did what convincor suggested, except that after I removed both sides of the nut with the cut-off wheel, I just grabbed the remainder with a pair of ViceGrips and it twisted right off.
