68 f100 restoration.
Fordkid68
Re: 68 f100 restoration.
Post by Fordkid68 »
cumminskiller wrote:Nice! You're cruisin'! You can make in 6 months!
Thanks! I hope I make it.
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
Fordkid68
Post by Fordkid68 »
I have not been able to get a lot done in the past week, but I did make some progress. I have been working on the heater. I tore it apart and cleaned everything. Now I just have to wait for it to stop snowing again to paint it!
This is before I tore it apart.
I even found an original stamping on the fiberglass heater box.
Here are parts cleaned and ready for paint!
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Well, it is still cold outside here, but I still painted the heater parts. I just sprayed them in the garage, and then hung them up in the basement to dry. I used Rust-Oleum Gloss black, and for some reason it was really runny, but hopefully it will be okay.
Adam
My first truck,
^^Build Thread^^
jimmy828
Post by jimmy828 »
Fordkid68 wrote:Well, it is still cold outside here, but I still painted the heater parts. I just sprayed them in the garage, and then hung them up in the basement to dry. I used Rust-Oleum Gloss black, and for some reason it was really runny, but hopefully it will be okay.
Looks good. I think the rust-o-leum paint takes to long to dry/cure. That's what i used until i switched to VHT which i like a lot more.
Fordkid68
Post by Fordkid68 »
jimmy828 wrote: Looks good. I think the rust-o-leum paint takes to long to dry/cure. That's what i used until i switched to VHT which i like a lot more.
Thanks for the tip! I have never heard of VHT, but I will definitely look into it.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Well, after a few days of working on it, the heater is finally assembled! I wasn't happy with the paint finish on the fiberglass box, so I sanded it down and repainted it. Then I assembled it with a seal kit from LMC, and a core from Rock Auto.
Now on to bigger and better things!
Adam
My first truck,
^^Build Thread^^
lontron
Post by lontron »
Thanks for this post and the updates. I'm finally getting back to a 67, my first vehicle, and I'm looking for inspiration. I got it back in 1986 and it has sat and been pretty bad, but its making headway now.
Fordkid68
Post by Fordkid68 »
lontron wrote: I'm finally getting back to a 67, my first vehicle, and I'm looking for inspiration. I got it back in 1986 and it has sat and been pretty bad, but its making headway now.
Welcome to the forum! Looking at other peoples projects is a great source of inspiration!
Adam
My first truck,
^^Build Thread^^
jimmy828
Post by jimmy828 »
heater box looks good. Hard work pays off :thup:
Bullitt74
Post by Bullitt74 »
Well done young lad!!
Tip: use SEM vinyl/plastic dye for plastic stuff (like your fibreglass heater box), and you’ll be surprised how nice that stuff turns out. I like the satin black...
Steve F.
Red Deer, Alberta, Canada
8)
Fordkid68
Post by Fordkid68 »
Bullitt74 wrote:Well done young lad!!
Thanks for the tip! I will definitely try that!
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
I have been stripping more paint off the firewall, and found more rust. :cuss:
Got it cut out.
Patch lined up.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Here it is all welded in.
Almost ready for paint.
Adam
My first truck,
^^Build Thread^^
Bullitt74
Post by Bullitt74 »
Looking good!
For your butt welds, try leaving a gap about the thickness of your metal. You should get a bit cleaner, tighter weld.
Although it looks like you’re doing a fine job as is! :clap:
Fordkid68
Post by Fordkid68 »
Thanks bullit74! I will try that.
Adam
My first truck,
^^Build Thread^^
