Are 4x4 F250's supposed to have a pwr steering cooler?
- fomocoguy
Today I noticed that my power steering pump on my highboy gets pretty hot. Does anyone know if it is supposed to have a factory ps cooler on it? It's a factory style power assist setup. Thanks!
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- SteveC
Re: Are 4x4 F250's supposed to have a pwr steering cooler?
it wouldnt be hard to put one on it. some trucks had a bunch of extra metal line that was on the return line before it went back into the pump aand on some they had a small looped over metal with fins on it.
for my efi swap i put one off from a early 80's on it... it was just a metal line that kinda snaked around the front cross member on my 2 wd
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- heep70
Factory cooler or better should be added.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- fomocoguy
Ok, well I guess I'll start looking for one. Thanks!
Joe
2005 Ford Ranger
2005 Ford Ranger
I've only seen them on 2wd trucks. When that setup was on mine I never had a problem but it was never driven much. The length of the lines alone should be good enough to cool it down. My 77 F150 4X4 uses just the return line as a cooler. My neighbors 76 F250 4X4 doesn't have one either. Not saying you wouldnt benfit from one...just never seen one on a 4X4.
- fomocoguy
Well the only reason I was concerned is because the pump I installed (an old original from a 76) started making a little noise at idle and it seemed pretty hot. It may just be the old pump, but I didn't know if they had a cooler from the factory. Thanks for the input! I may just replace the pump and see how it does.BigBlueF250 wrote:I've only seen them on 2wd trucks. When that setup was on mine I never had a problem but it was never driven much. The length of the lines alone should be good enough to cool it down. My 77 F150 4X4 uses just the return line as a cooler. My neighbors 76 F250 4X4 doesn't have one either. Not saying you wouldnt benfit from one...just never seen one on a 4X4.
Joe
2005 Ford Ranger
2005 Ford Ranger
- averagef250
The Ford pumps aren't great (read suck). If it's an option for you the saginaw pumps are much better. You can buy conversion pumps to replace the ford ones, but they do not fit truck FE brackets well with the canned ham reservoir. What I like to do is just get a GM saginaw pump from a diesel or big block that has the small remote mount resevoir on it. I cut the center out of the GM bracket and weld it right to the front of the Ford bracket with the resevoir tube pointing to the side. I mount the resevoir wherever I need it and run the GM pulley. This also works great if you have hydroboost brakes since the GM cans already have the H-boost return built in.
