72 heavy 250 to 68 light 250 disc swap
bike5087
Post by bike5087 »
Hi all -
I just want to make sure I get what I need- so I thought I'd throw this out to all you experts. I have a light (6100gvw) 68 f250. About an hours drive from me is a 72 donor with discs that I want to swap. I am assuming this 72 has a heavier gvw because it was a camper special. Do you think I can swap just the spindles,etc? Or do I need to get the whole front end?
fireguywtc
Re: 72 heavy 250 to 68 light 250 disc swap
Post by fireguywtc »
Just the spindles out is all you should need. I just did this on my 67, spindles when right up to the old I-beams no problem.
Bill
read this first. read both pages and check the king pin diameters. that will tell you what parts to get. http://www.fordification.com/discbrakes01.htm
Hawkrod
Post by Hawkrod »
Also, never assume the GVWR of a truck just because it has an option package. The camper Specials came in light weight and heavyweight configurations, the person ordering the truck made that call, it was not standard. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
bike5087
Post by bike5087 »
Thank you all for your quick response - I ended up just getting the whole rolling chassis from the donor. Frame, suspension, brakes,etc. Any ideas on how to hook the vacuum lines needed for the power brake booster? Also - I will end up having a Dana 60 rear axle leftover if any one needs one.
bike5087
Post by bike5087 »
I think I will also have four 16.5" wheels with dogdishes, I will take photos and post in the proper forum.
the brake booster vacuum hose hooks ontot he main manifold vacuum port. it looks like this on a fe engine.
bike5087
Post by bike5087 »
Thanks again- I'm sure I'll have more questions once I get started on this project.
sideoilerfe
Post by sideoilerfe »
If you don't want the dog dishes i'll take 'em.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
