I currently have 2 problems right now with the brakes.
1. When the engine is running the master cylinder leaks fluid out around the top. I have replaced the seal on the lid and also the entire lid still same problem. Any suggestions?
Oh yea the brake booster and master cylinder are newly reman. from advance auto.
2. I used the mounting plate from a 1973 when I upgraded to disk brakes and I mounted the plate upside down. didn't think nothing about until I hit a bump and it mashed both metal blake lines flat. Anyway replaced the brakets with the original 67 ones and replaced the metal brakelines and bled the brakes now the front brakes won't release they are tight. It almost acts like the master cylinder ain't releasing or the calipers ain't releasing No problems with brakes before I mashed the brake lines flat. Any suggestions on this?This is the bracket I was refering to that I had upside down . JPG[/attachment]
Master Cylinder problems
- Roadrunner351w
Roadrunner351w
Re: Master Cylinder problems
replace the master cylinder to fix both problems. that just happend to soemone else. just less than a month ago. just check a few of the last posts on this page. it is in there someplace. he had replaced the master and got a bad one and had to replace it again.
- Roadrunner351w
Thanks for the input. I was already kinda leaning that way.
Roadrunner351w
- Roadrunner351w
Thanks again I replaced the Master Cylinder with one off a 1993 Ford F150 with a screw on cap and it works great.
Last edited by Roadrunner351w on Mon Feb 09, 2009 11:07 am, edited 1 time in total.
Roadrunner351w
- Roadrunner351w
Thanks again. Maybe everyone can benefit from the previous post about the Master cylinder. The off off a 1993 F150 works great and it looks good also.
Roadrunner351w
just as a note the master cylinder is rated to go with certain sized wheel cylinders and disc brake calipers. if you have a mastere that controls a wrong sized wheel cylinder or caliper it mihgt not work properly down the road sometime.
