While putting my front end back together on my 8,100lb GVW F250, I noticed a difference between the diagram in the shop manual and my setup. You know the large nut that's supposed to sit right under the bell-shaped lower spring mount plate? I left this nut out when putting my front end together.
At first I thought the nut didn't come out, since I couldn't find it in any of my tear down photos. But then I found two mysteriously out of place and large nuts sitting in the garage! Whoops!
So here is my question: Do all Bumpsides have that big nut that's circled in blue below? Or do some only have the big nut that's directly on top of the lower spring mount plate?
PS. The image is from my computer version of the 1972 Shop Manual, which I'll review in a separate post later on.
Thanks very much for the expert advice!
-Robroy
