I beam selection
I beam selection
Who has the best lowering I-beams? I am getting ready to start the parts ordering process and I would to get some feed back. DJM, Belltech and AIM all have lowering I-beams available. Who has the best and easiest to work with. At this point cost is not an issue. I am lowering a 1968 F100 and I will be using 1978 F150 donor spindles. All the info I get will be greatly appreciated
- td
Re: I beam selection
festus,
i used the DJM'S and had a good experience with them.
i would recommend them to anyone.
BTW Welcome to the site, you should stop by the welcome mat and introduce yourself .
i too used the djm and would recommend them as well
also 68s are the best. check out mine and td s photobucket
also welcome from tennessee
Another vote for DJM.Just be sure to get the I beams for the spindles you will be using.Welcome aboard and keep us posted on your progress,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
Thanks for the info gentlemen, I really appreciate it.
- td
festus,
there's another thing we failed to tell you, aims industries is another company that sales lowering beams for our trucks. a good detail you may or may not know about their beams is that they are a inch or so longer than the djm's, so you would end up with a wider track width in the front compared to the djm's.being that these trucks already have a wider front track width from the factory makes the aim's beams a little less desirable choice. i don't know witch one's you'll end up going with but this is good info to have in helping you make a decision.
good luck and please keep us updated on your progress.
