Brake calipers
TheeMc
Brake calipers
Post by TheeMc »
I have the dual cylinder disc brake calipers on the front of my truck, and was wondering if there is a vender that carries these rebuilt? My brakes are kinda jerking, or surging??? maybe, feels sorta like an anti lock system when I stand on the pedel with fairly good pressure. I was figuring on replacing the master cylinder and both front calipers, and having the roters turned.
One more question I guess, is ther any difference in the master cylinders, for the disc brakes, for single cylinder or dual cylinders?, and or the vacuum boosters?
I already had the back brakes completly rebuilt two years ago, and thay have maybe 5K miles on them.
Thanks!
M
TheeMc
72 F-250 C/S
Why do we drive on a parkway, and park on a driveway?
"98% of all Dodge trucks are still on the road;
The other 2% actually made it home..."
kaptnkaos
re: Brake calipers
Post by kaptnkaos »
Hey Bro,
NPD lists the calipers for a '72 F-250 but doesn't say if they are for the CS model or not... They list part number F-2B120-5 for either side...
NPD lists 2 MC's F-2140-18 and F-2140-8 (equal reservoirs)
They're in Charlotte so give them a call 800-368-6351
Hope that helps...
tfnaaf
Post by tfnaaf »
i just searched our local parts warehouse and they have both single and dual piston calipers in stock. you may want to try local parts stores first
i bet you just need to turn your rotors.
TheeMc
re: Brake calipers
Post by TheeMc »
Thanks!
I will check with NPD, as well as local parts houses for the calipers, (if needed). Actually the MC, and calipers are just about all that is needed for a complete brake re-build. The PO had all new steel lines put on, and I replaced the rear wheel cyinders, and front hoses a couple of years ago. So really all that is needed for the rebuild to be complete is the calipers and master cylinder. If the rotors are in good enough shape I will simply have them turned.
Thanks again...
M
TheeMc
72 F-250 C/S
flyboy2610
Post by flyboy2610 »
