Master Cylinder Question
derek7871
Post by derek7871 »
My '68 F-100 has drum brakes all around....no power assist. About a year ago I had the brakes pretty much reworked, including a new master cylinder. They put a master cylinder with a larger reservoir in the back (for the front brakes). Since I have drum brakes all around, can I expect any problems running a master cylinder that is designed for disc brakes up front?
Cooter
SteveC
re: Master Cylinder Question
Post by SteveC »
my 67 is all orginal and it has a larger rear reservior than is in the front with drums all around
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
it is fine with drum brakes the only way the master cylinder resivors need to be larger in the back is for disc brakes. they work fine with drum brakes. but you cant have a same size resivor for disc brakes.
Thunderfoot
Post by Thunderfoot »
I just put a new master cylinder on my 69 Highboy with Drum-Drum and it also has a bigger reservoir on the back side (front brakes) then the front... (the old one that was on it was the same way) I think the manufactures now days are just using the same reservoir casting (saving money) for both systems and just removing the residual valves in the ones for the disc setups... :2cents:
Shayne
derek7871
Post by derek7871 »
Good to know. One less thing to worry about.
Cooter
