brak conversion on 68 with 73 stuff
Joshpow
re: brak conversion on 68 with 73 stuff
Post by Joshpow »
Here is a link to the discussion about the F100 Nationals.
http://www.fordification.com/forum/view ... highlight=
Hope we can get more to attend.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
sargentrs
Post by sargentrs »
fordman wrote:so who is building a show truck for the dump guy to see? :lol: :lol:
I've got a "dump" truck for the show guy's to see! I may not even empty out the trash. :wink:
427blackpearl
Post by 427blackpearl »
not a show truck just a cool hot rod to me. i will share my story. its a 68 ranger i bought from owner 1 in north ga. he used it on farm and to coon hunt its black/red i just put the djm beams and rear hanger and shakle also front disc thats the reason for the post any way i still need to do rear disc all disc are drilled'slotted rear are for caddy/pbrake next is red steal reams or the 17'' american racing torq thrust i will try the prop valve tomarrow and let you all know thanks to all who gave their two cents
kaptnkaos
Post by kaptnkaos »
my turn :evil:
:nopix:
KaptnKA 8) S
hickchemistry07
Post by hickchemistry07 »
Oh yes, I'll definately be going to the Nationals!! :D 427 if you some help, I'd be willing to volunteer(when I'm not working). Because I plan on doing the same upgrade to my '71 in the future. That's the great thing about this site, usually if I'm having a problem, with a little reading, I find that someone out there has had the same problem and found the cure.
Anyway, every once in a while I make it up that way to the P-A-P and would love to come by and check out your ride.
:fr:
427blackpearl
all right the parts truck is a 76' disc/drum no power should i use the prop valve from this or since i am going to put rear disc later should i just get an adjustable one that i can use now and later
customcrewcab
Post by customcrewcab »
yep. i would just do that so you don't have to do it later. :thup:
427blackpearl
so how does this adj prop valve work and where do i install it do i keep my mastercylinder fo 73 disc/drum what brand do i use
customcrewcab
full pressure goes to the front and the adjustable one goes in line to the rear. it just makes it so the rear brakes don't grab first. i got a wilwood one off ebay but thats just because i have a wilwood master and calipers on all 4 corners. i figure keep it all matching. heres some on ebay. the 28.00 will work fine thats in the ebay store.
http://search.ebay.com/search/search.dl ... category0=
Thunderfoot
Post by Thunderfoot »
Unfortunately I think your problem is probably that the font calipers are frozen (pistons rusted in place) could you move them before you put them on?
Although the proportioning valve is a good thing to get the right one set up, it will not effect the operation of the brakes to work, they just wont have the right proportioning front to rear by a small percentage (you wont tell this until you put the brakes on hard).
Does the brake peddle feel hard? If the calipers are frozen then once the brake peddle stops moving, because it can’t move the fluid anymore for the fronts, it will not let the backs get any pressure either so no brakes… :2cents:
Shayne
427blackpearl
thanks for the help i may need to rephrase my question i put new calipers with drum/drum mastercylinder old mastercylinder worked fine after instal brake pedel goes to floor no pressure instal a disc/drum mastercylinder pedal goes to floor i should have some petal hard or spongy but no. petal goes to floor pump 3-6 times some type of petal but sit for 3-6 sec. push petal goes to floor
427blackpearl
alright now we blocked the hard lines to the calp by doing this the mastercylinder is working we have a petal so the problem we think is the new soft lines to the calp or the calps them self what do you think
Thunderfoot
Re: re: brak conversion on 68 with 73 stuff
427blackpearl wrote:alright now we blocked the hard lines to the calp by doing this the mastercylinder is working we have a petal so the problem we think is the new soft lines to the calp or the calps them self what do you think
I doubt the NEW lines are bad... but check them to see if you see them bulge any...
I think you have an air pocket still stuck in the calipers.
Your not loosing / using any fluid correct?
EDIT: be sure that the bleeders on the calipers are pointing up in the highest position. I have seen some calipers that can be bolted either side and one way puts the bleeders down instead of up and you will never get the air out of them... Not sure if this is possible on these as I haven't done this mod on mine yet. (It's on my list though) :wink:
Shayne
427blackpearl
no bulges in the lines, bleeder is up, the only fluid we use is the fluid that comes out when bled out, we will try some old calps tonight
did you put on a porportion valve? you have to have that valve with front disc and rear drum brakes.
