brak conversion on 68 with 73 stuff
427blackpearl
Post by 427blackpearl »
help on disc conv. i am a newby so bear with me. i have a 68 no power any thing. i put 73 spindels,73 calip., 73 mastercylinder, for non power brakes front disc rear drum i have no leaks and no brakes what is wrong
customcrewcab
re: brak conversion on 68 with 73 stuff
Post by customcrewcab »
did you get them all bleed out. they have a kit so you can bleed out the master into itself so you can get most of the air out . then i would bleed out each corner. :thup:
427blackpearl
yea ,ms, all corners, i have done brakes before but never swaping to disc, also everybody has powerbrakes i dont! i dont think it has anything to do with it but i dont know also i will be doing all 4 corners with disc do i use a ms from drum/drum
so you got fluid to come out of each brake set as you bleed them? is the master cylinder used? maybe its bad.
427blackpearl
yea. fluid is clear no bubs at all corners all stuff is new. good ol dad thinks i need to let it set over night to let all the new seals soak. also not trying to get mushy but this site and the people on it rock! i thought it would take days to get a responce
Joshpow
Post by Joshpow »
Just wondering, did you change the proportioning valve also? If not, the discs won't get correct pressure. Also, the master cylinder has to change for the discs. My understandings is a drum master cylinder won't push enough volume to operate discs. If you use 4 wheel discs, you need a proportioning valve and master cylinder from a 4 wheel disc vehicle. If you use front disc rear drum, you need a disc/drum master cylinder and proportioniong valve. Also, I would suggest going power if you have discs. Just my :2cents: .
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
427blackpearl
no i did not change a prop valve i did change ms from drum/drum to disc/drum
Joshpow
Post by Joshpow »
you definately need a proportioning valve set up for your current configuration of discs and drums. If you have disc fron drum rear, you can use the prop valve from a 73-79. If you have 4 wheel disc,I don't know exactly what valve to tell you to use.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
427blackpearl wrote:yea. fluid is clear no bubs at all corners all stuff is new. good ol dad thinks i need to let it set over night to let all the new seals soak. also not trying to get mushy but this site and the people on it rock! i thought it would take days to get a responce
I LOVE YOU. how is that for mushy. brakes that is. yes you need the porportioning vavle for disc / drums when you do this swap. i am not sure this is the problem but it could be.
427blackpearl
thanks i will look at the parts truck tomorrow to get the valve off it if it has one also i put 4 wheel disc on a 71 bronco and used the mastercylinder for a 4 wheel drum no prop valve it worked great can i do the same for this truck
that could be a different deal than disc drums/ the front disc nedd a different pressure than the rear drums do. i would make a guess and say that the disc disc would need equal pressure all the way around.
Joshpow
Post by Joshpow »
I agree. The disc/disc would need higher rear pressure than rear drum. The drum/drum prop valve won't allow enough pressure to push 4 wheel discs I don't think.
Oh, and by the way 427blackpearl, are you going to the F100 Nationals show in Knoxville at Chilhowie Park? Us guys that are going plan on meeting up with one another somewhere at the show. Let us know if you plan to come.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
427blackpearl
yes. i'm not doing all this work just to look good when i go to the dump on saturdays. maby i will have it all dun by then.
427blackpearl
p.s. how many people from this site go or get together there
so who is building a show truck for the dump guy to see? :lol: :lol:
