can i use 77 grand marquie frame?
EppersonRacin
Post by EppersonRacin »
its been a while since iv been on here but didn't someone put a 67-72 swb truck body onto a grand marque frame? i found a 77 G-M with a 460 (running-driving) for $500. btw i also have a 85 LTD chassis i can use also..if that would be better
or would it be easier to use the frame its on and swap everything out.
if it helps this truck is getting bagged..and a semi built 460..
if there is a better way to build this im open to suggestions :)
thanks for all the help in advance!
pic of what im working with..
i dont know what to say. what are you trying to get from the marquis frame? the disc brakes?
Banjo
re: can i use 77 grand marquie frame?
Post by Banjo »
Can't say for FOMOCO products, but I checking into for GM, as I had a similar tank and was going to prop body up and roll chassis out from under (Buick) to put under some other vehicle and at least GM went to a "perimeter" frame, which means it's way over right underneath rocker panel as far to the outside as possible. So, it's not like older GMs. Can't comment about Ford products, but that's what I'd check, how far inboard are the frame rails. I'm sure if those were in fairly close proximity, anything can be shortened with cutting/welding the frame and I'm guessing Grand Marquis frame longer than SWB bumpside.
EppersonRacin
trying to get away from those i-beams and disk brakes also
layedout72
Post by layedout72 »
I believe you can, I can't remember the guys screen name on here to save my life. He used a GM, but a 90's model. He had mentioned they never did change really, maybe a couple differences but from mid 70's-2007 they have yet to change drastically.
EppersonRacin
marz68 posted up this link for irs
http://team321.com/truckirs/truckirs.html
sooooo...iv changed my mind on the GM frame now i need something for the front, how hard and expensive is it to do the mustang 2? front end on one of these trucks? is there a kit, is it bolt in?
lightning_msd
Post by lightning_msd »
i dont know if it would work for a bump, but i met a slick60's member and he was looking for a newer crown vic with an aluminum crossmember and suspension setup that i guess bolts up to the same dimensions, my idea, because my brother has a 67 country squire that has the same wheel base length as my lwb bump... my idea was to find another one and see if i could use the whole setup from that car, it has 4 link rear suspension, and IFS, and since its basically a galaxie im sure i could find parts for it.
marz68
Post by marz68 »
I got something cooking for you guys wanting to lower your trucks without i beams but I don't want to let the dog out just yet until I instal the kit on a truck and drive it. I am currently looking for some one that would like for me to use their truck for the test.
lightning_msd
marz68 wrote:I got something cooking for you guys wanting to lower your trucks without i beams but I don't want to let the dog out just yet until I instal the kit on a truck and drive it. I am currently looking for some one that would like for me to use their truck for the test.
do we have to be close? ill donate mine if not... :D
marz68
Post by marz68 »
any one person that can drive their truck to my back yard is welcome. Almost forgot, the truck must be 70-72 since 67,68,69 crossmembers are different than 70,71,72. I was only able to get a 70-72 crossmember but I will build one for 67-69 trucks too.
marz68
Post by marz68 »
oh it must be a 1/2 ton 5 lug too :clap:
EppersonRacin
someone hurry and donate a truck, i wanna know what hes not telling :)
lightning_msd
no love for the 67-69s? :(
EppersonRacin
marz68 wrote:I was only able to get a 70-72 crossmember but I will build one for 67-69 trucks too.
lightning_msd
i know but he shoulda built the 67 one first :D :P
