Is it safe? washer with late steering parts, early spindles
ima71 trucks are older
Post by ima71 trucks are older »
Is it safe to use a thick washer under the nut holding the tie rods to the spindles when using late tie tods/drag link with early spindles, in order to locate the castle nut at the right height to use a cotter pin. The tie rods look like the same size/taper, just a little longer.
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
kid
Post by kid »
The nut sits at the right place on my 350. I have a later 100-250 one on my 69 and it fits fine.
averagef250
Post by averagef250 »
I've had to do it a few times. Should be fine.
import600
Post by import600 »
you can get a taller castle nut at a parts store. It should be a buck a piece.
kyle
kyle
1971 F100 2wd swb 429 C6
kid
Post by kid »
You don't need it the nut that came with the longer spindle end and the old nut are the same. I used the new end and the new nust with no problems on the 69
Kid's right, even though the later tierod/draglink ends are definatly longer everything snugged up fine. :) :fr:
Something went right and was easy :clap:
69 F100 300-4spd
78 F150 300-3spdOD
