Axle Pivot Bushings
Stumpfoot
Axle Pivot Bushings
Post by Stumpfoot »
I searched and searched but couldnt find a thread on this topic. Whats the best way to change out the axle pivot bushings on a 67? I've pulled and prodded but the things wont budge, this isnt something I will have to have pressed out and in is it?
averagef250
Post by averagef250 »
What bushings are you talking about?
Stumpfoot
re: Axle Pivot Bushings
Post by Stumpfoot »
The axle pivot bushings.
customcrewcab
Post by customcrewcab »
4wd or 2wd :?
customcrewcab
bearing races :?
Wes
Post by Wes »
yes pressing it out is the best way, you might be able to do w/ axle in truck and big C clamp. A air hammer with a blunt bit might do the trick as well.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
Stumpfoot
Post by Stumpfoot »
It's the bushing where the I-Beam connects to the frame....2 wheel drive.
customcrewcab
yes arbor press would work. if you take it a shop they can press them out and the new ones in :thup:
Stumpfoot
Post by Stumpfoot »
I just hate taking the whole thing in and asking them to press out that bushing with the spindal and everything hanging on it (cause I aint going to wrestle with that king pin.)
customcrewcab
well you have a torch? melt them out or enought where you can get then out with a hammer. put the news ones in the frezzer and ste the beam in the sun where they can get hot. they will go in easier
390Nut
Re: re: Axle Pivot Bushings
Post by 390Nut »
Stumpfoot wrote:I just hate taking the whole thing in and asking them to press out that bushing with the spindal and everything hanging on it (cause I aint going to wrestle with that king pin.)
What kind of shape is the king-pin in? If the axle pivot is worn out, I can guarantee the king-pin is too, if it's not been replaced.
It's notoriously expensive to get mechanical stuff done around here, but having the pivot bushing swapped out for me only cost me $60.00. Worth it to me, cuz I spent all the time I WOULD have spent working on them, working on other things.
Just my :2cents:
Paul
`69 F100 390 4spd driver
Stumpfoot
Post by Stumpfoot »
I have one of those little handheld butane torches, but I suppose that would do if all I was doing was removing a bushing.
dcbullet
Post by dcbullet »
Yeah, just bite the bullet and take it to a machine shop. I dropped mine off at 9am and picked up at noon. Got the king pins done too. You might as well so you don't have to bother again for 40 years.
You can also drill out the rubber on the old bushings, and then bend/pry the bushing shells out. Then you can use a long bolt, nut and a couple of large washer to pull the new bushings in.
However, it's a lot of work...I'll second (third?) the suggestion of just dropping it off at the machine shop. And I also agree to getting the kingpins replaced while you've got everything down that far. Be honest...do you think you'll ever have the front-end tore down this far again in the future? Get it done now and keep it greased up, and they'll outlast the rest of the truck. Just my :2cents:
Wes
Post by Wes »
You can do the pivot bushings in the truck w/ this tool Image
40.00 at Harbor Freight.
Wes
67 F250 High boy
69 Bronco
