Brake question
Dunnburger
Brake question
Post by Dunnburger »
I have a 68 F100, converted front to disc with 74 spindles and calipers, I order brake booster with new master cylinder. My question is, do I need proportioning valve or combination valve specific to the 74 set up or can I get an aftermarked prop valve and put it on the rear line only and adjust how much brake goes to the rear and have the discs directly to the master cylinder?
MadMaxetc
Post by MadMaxetc »
You can use an aftermarket one to adjust front/rear biast. You will need a splitter for the front.
Any distribution block from 73-79 with disks will work if you want to use a stock peice.
Dan
FORD Girl
Photobucket Pictures
theskytoucher
re: Brake question
Post by theskytoucher »
If you use the aftermarket style you will also need residual valves which hold a small amount of pressure in the calipers so that your pedal throw is still short. And there are 2 lb and 10 lbs style valves and each one goes with a specific type of brakes (disc or drum) but right now i can remember for the life of me which is which!!!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
68F250
re: Brake question
Post by 68F250 »
The residual valves are already built-in the master cylinder. Now you have to get the correct mc (for front discs or drums) in order to get the correct valves.
Barry
