looking to buy AR Torq Thrust D Wheels for 68 F100
Has anyone used these rimes for their truck and, if so, is the bolt pattern 5X5 or 5X5.5...what is the difference in these numbers? I am looking to purchase 15 X 7 wheels and trying to figure out which ones are correct.
Many thanks.
68 F100 Ranger in 100% original condition about to go through a restoration.
Many thanks.
- Big D's 69
5 on 5 1/2 is the lug pattern.
- 68F250
re: looking to buy AR Torq Thrust D Wheels for 68 F100
Haven't bought those but you need 5x5.5, the 5 is the # of bolt holes and the 5.5 is the bolt circle diameter.
Barry
- Big D's 69
Taper Bore?wjmanson wrote:Any idea what the 'taper bore' for this vehicle would be?
Thx!
- Big D's 69
Oh that may be the size of the axle hub in the center.
- rjewkes
Any good tire shop worth its wieght ingold should be able to measure it for you.
- bryantracing460
Yes, same bolt pattern up to 96.
Jeremy
Drive It Like You Stole It.........NO FEAR!
69 F-100 swb 2wd 460 C-6. 86 F-150 super cab 2wd 302 AOD.85 Bronco 4wd 300 AOD.
http://www.myspace.com/bryantracing460
The tapered bore is 3.420 on the wheel and the hub is JUST under it and might need to be turned down a little. I brought my hub up to a wheel shop one day and they measured it for me and it was 3.410 or something around there and they said that it would work but BARELY made it. Another wheel shop said they wont work but they never tried it before. I have seen these wheels on these trucks a few times so I know it works and I will be getting the Torq Thrust II's with the grey centers and polished outter (they are called CL205's).
