Is the bell housing bolt pattern the same on a C4 than a AOD? If so, couldnt you use this to put an AOD in an FE??
http://store.summitracing.com/partdetai ... toview=sku
Quick Question
- blue68
- averagef250
- 46stude
FE's have their own unique bell pattern.
Y blocks have their own pattern.
small block Fords (289/302/351W) & the small and big 6's share the same bell pattern.
335 series (351C, 351M/400) and 385 series (429/460) share the same bell pattern.
IIRC, 351C can be either big-block or small block patterns- best to check.
Ford had its own way of doing things, & sometimes its a real PITA!
'69 F350 Project....well, kind of.
FBF coined the name:
Stude-a-bumper
The Studebaker/bumpside hybrid.....
Stude-a-bumper
- Clarko
Ok, to answer your question: The AOD bell is not removable. It's like a C6 in that way. It's a cast part of the case.
Here is the adaptor you need: http://www.transmissionadapters.com/ford_fe.htm
Install instructions: http://www.transmissionadapters.com/For ... nstall.htm
Cost is $750, though...
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
- Clarko
- rjewkes
cool too bad the bird is penmding sale or i'd have a strong aod to use in the truck.
