460 oil pans
M-100
460 oil pans
Post by M-100 »
I have a 460 for my f250 that some gobber put a 350 motor in . I like the truck but I can't take that engine anymore. So I bought a van with a 460 and found mounts from a dentside. Will the van oil pan work ? I would like to use it since I already own it.
cep62
Re: 460 oil pans
Post by cep62 »
The van has a rear sump. that's needed for a 4wd.
I'm not sure if it'll fit a 2wd.
70shortbox
Re: 460 oil pans
Post by 70shortbox »
I have a van pan on mine. Fits great and the drain plug is in the right spot.
1970 F100 Custom Shortbed Styleside
460/C6
M-100
Re: 460 oil pans
Post by M-100 »
Thanks for the response. Is your truck a two wheel drive 70 shortness?
M-100
Re: 460 oil pans
Post by M-100 »
I didn't type shortness but that's what we got
70shortbox
Re: 460 oil pans
Yes, 2wd short bed.
460/C6
M-100
Re: 460 oil pans
Post by M-100 »
I have been trying to find out on the interscreen some said it would work and others said it would not. Thanks 70 for clearing it up.
70shortbox
Re: 460 oil pans
This pan is from an 84 E350. Its not as close as the pictures make it look. It has a very deep sump. 6 quarts. Must use the dipstick that came with it.
460/C6
M-100
Re: 460 oil pans
Post by M-100 »
The one I have is from a 78 but looks identical to that. Thanks again 70 you saved me about 200 bucks.
