Fuel tank smell
dave1972
Fuel tank smell
Post by dave1972 »
Who has the best trick for sealing up the fuel sender on the interior gas tank?
jzjames
Re: Fuel tank smell
Post by jzjames »
Check the condition of the inner hose/gas tank connection
bellamor
Re: Fuel tank smell
Post by bellamor »
You can find the answer to this problem by reading this article:
https://www.classictoyotatyler.com/blog ... o%20detect.
:fr:
dave1972
Re: Fuel tank smell
Post by dave1972 »
Thanks guys. Fixed the leaky, although new, sender gasket with permatex perma-shield. Highly recommend this to anyone. Throw the gasket away. Apply perma-shield liberally. Let it set up for a bit and screw down the sender. No leaks since. Perma-shield is a gasoline resistant sealer.
bellamor
Re: Fuel tank smell
Post by bellamor »
dave1972 wrote:Thanks guys. Fixed the leaky, although new, sender gasket with permatex perma-shield. Highly recommend this to anyone. Throw the gasket away. Apply perma-shield liberally. Let it set up for a bit and screw down the sender. No leaks since. Perma-shield is a gasoline resistant sealer.
I am glad that you have managed to solve this issue. Thanks for the tips!
