Hello All,
The heater in my f100 is always blowing. It always starts to heat up after the engine is warm. I installed a new thermostat and nothing has changed. Any ideas?
Thanks.
Heater issues
Heater issues
1970 F100/302 5.0/4 speed/ Ford9inch 3.70
Re: Heater issues
I would check the in-line valve in your heater hose first, they often get rusty and won't open and close properly. Here is a thread that talks about the similar problem to yours: https://www.fordification.com/forum/vie ... =6&t=96179
Let us know if it is working or not, I would suggest that you pull it and make sure it looks like it is working properly.
Regards
Regards
Re: Heater issues
You were right! The heater valve was stuck open.
Thanks so much.
Thanks so much.
Re: Heater issues
Glad to hear you got it fixed!
Re: Heater issues
Ok. So I thought that replacing the in-line valve and the heater hose worked, but it did not. The heat just blows when I'm actively driving down the road. When I stop at a light there is no heat. Any ideas?
Thanks.
Thanks.
Re: Heater issues
https://www.dennis-carpenter.com/trucks ... -fresh-air.
The "foam" seals deteriorate with time. This is what you need to fix that. I am doing this in mine right now.
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
