I just had my 1970 3/4 ton’s 390 engine completely rebuilt. I have driven a few hundred miles and I am looking to change the oil. What kind of oil should I use?
Thanks!
Alex
Oil for a rebuilt 390
- cougswan
1970 Ford F250 390
Re: Oil for a rebuilt 390
Ughhh. Such a huge debate.
I use Mobil 1 15-50w. https://www.walmart.com/ip/Mobil-1-Adva ... ected=true
It contains the ZDDP additive that flat tappet cams require and is trustworthy from Mobil 1. Better yet, it is cheap from Walmart.
However, I have also tried Lucas Oil https://www.walmart.com/ip/Lucas-Oil-Ho ... t/49692050
Either way, they are both great. Just be sure you have zinc in there and try to avoid additives to oil because some don't play nice together.
Since it’s a rebuilt motor I wouldn’t run anything thicker than a 10w-30 because of the tighter bearing tolerances. The topic of oil is a tricky one cause everyone has a different opinion. Bottom line I would run an oil with ZDDP/Zinc. Good choices are Vavoline VR1, PennGrade, or Schaeffer's. Personally I run schaeffer's in my Ram 2500 w/ 6.7l CTD and plan on running their 10w-30 when I finish my 390 rebuild.
1972 F250 Ranger XLT Camper Special 390ci Bought Brand new in 1972 and passed down from my Grandpa after he passed
![Image](http://i.imgur.com/t20RJ.png)
RIP Paul & Von
RIP Paul & Von
