How to tell oem from aftermarket tail gates?
I have a old 73/9 tail gate but with all the aftermarket repop’s out there how do you will the clean oem ones from the repop’s ? The one I have don’t have any lettering on it but has the tabs for the trim that went across the gate
Re: How to tell oem from aftermarket tail gates?
Big specht wrote:I have a old 73/9 tail gate but with all the aftermarket repop’s out there how do you will the clean oem ones from the repop’s ? The one I have don’t have any lettering on it but has the tabs for the trim that went across the gate
Dennis Carpenter offers both the OEM style and a re-pop import. The OEM style is made with the original tooling, and is made of galvanized steel, so it won't rust like the original tailgates.
https://www.dennis-carpenter.com/en/tru ... -styleside
https://www.dennis-carpenter.com/en/tru ... ide-replac
Hope this helps!![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
Hope this helps!
- FLASH 1
easy way Ford gates says Ford, Junk Tawains or anybody else's will not say Ford since they are to cheap to pay Ford for the royalities
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
We got an incoming '79 truck project after we finished installing the suspension and ridge grappler tires on the current Wrangler project. We're going to need a tailgate with Ford lettering. Thanks390FE1972 wrote:Dennis Carpenter offers both the OEM style and a re-pop import. The OEM style is made with the original tooling, and is made of galvanized steel, so it won't rust like the original tailgates.
Hope this helps!
You can't hardly carry an original by yourself compared to a re-pop. (At least for an old guy like me).
- two-bit
The originals are way heavier than the repops. Not sure what the weight difference is, but it is very noticeable.
Two-bit
