dust shields
Bob 2+2
dust shields
Post by Bob 2+2 »
Hello fellow Ford truck lovers
I'm finally getting around to doing the disc brake swap on my 1971. Found a 79 donor truck and have everything except the dust shields which were no good. Anyone know if they reproduce them or of a good place to find NOS or if anything else will fit. Buy the way it's 2 wheel drive.
390FE1972
Re: dust shields
Post by 390FE1972 »
Bob 2+2
Re: dust shields
Post by Bob 2+2 »
Thanks I'll check those places out
Re: dust shields
Good luck...
I’ve come up empty...
sargentrs
Re: dust shields
Post by sargentrs »
Anybody know what the difference is in a '76-'79 4x4 dust shield vs the 2wd? Those appear readily available.
Booyaa138
Re: dust shields
Post by Booyaa138 »
I have some from a 73 that I would let go. I have no idea if they would work.
Let me know if you want them.
Re: dust shields
Booyaa138 wrote:I have some from a 73 that I would let go. I have no idea if they would work.
If OP doesn’t want I will take them, PM me.
Bob 2+2
Re: dust shields
Post by Bob 2+2 »
I was wondering about the difference between the 4X4 and 2wd dust shields myself. Must be some difference but maybe you could make them work.
any one out there tried it?
Bob 2+2
Re: dust shields
Post by Bob 2+2 »
Yea I'm pretty sure that the 73 dust shields will work on a 79. I sent you a private message. Let me know what you want and if they are in decent shape.
They are for 2wd F100 or 150 right?
Re: dust shields
The obvious differences are that the 4x4 has a much larger center hole and 5 vs 3 mounting holes.
It might be possible to make an adapter but you’d have to try it, I would be likely to try another 2 wd application first though...
basketcase0302
Re: dust shields
Post by basketcase0302 »
"DuckRyder"The obvious differences are that the 4x4 has a much larger center hole and 5 vs 3 mounting holes.
Robert, (DuckRyder) is spot on here guys as I owned a 76' early Bronco, (same axle tube) for some 20+ years and dissasembled it too many times to count for maintenance.
Booyaa138
Re: dust shields
Post by Booyaa138 »
Bob 2+2 I got your PM.I can't respond to you because I'm to new to this forum.
They are off of a 2wd F100. Pm me your Email address and I can take some pics and send them to you.
FLASH 1
Re: dust shields
Post by FLASH 1 »
The 73 and maybe 74 dust shields HAS NO Vent in them as where the later ones has a vent on the dust shield to keep the brake rotors cool 4x4 and 2 wheel WILL not interchange
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
Bob 2+2
Re: dust shields
Post by Bob 2+2 »
Thanks for that info Flash1. Must of made an engineering change sometime early in the 73 -79 models. Do you know if the 73 will sill still bolt on a 79?
Bob 2+2
Re: dust shields
Post by Bob 2+2 »
Hey Booyaa138 I sent you another PM with my email. Flash1 posted that the 73 model dust shields didn't have a vent like the later models but as long as they bolt on I would still be interested.
