Exhaust y-pipe install - 1969 f100 360, AT
ajboots4
Post by ajboots4 »
Can I get some suggestions on how to install the exhaust Y-pipe? Seems like the transmission crossmember and the starter motor should be removed to be able to get the Y-pipe in there. Unfortunately I don’t have the benefit of a lift while I’m doing this.
1969 F100, long bed, 360, 2-barrell, rust-bucket, tinkering victim
fastEdsel
Re: Exhaust y-pipe install - 1969 f100 360, AT
Post by fastEdsel »
My Edsel is really low and so are a couple other of my projects so what I did was use regular car ramps and place a long chain on both ramps from the little hole in the front of the ramps to the front bottom of the rear wheels. Drive your vehicle, I know it will be loud, on the chains and they will pull the ramps or hold them in place while the front wheels roll onto the upper bowls of the ramps. I know it's a poor mans fix but it works and is safe. The ramps hold fast and won't run away on you. Y-pipes are my preference of pipes for the 360, single exhaust out the right rear of your vehicle. Sounds great, performance shouldn't change. :thup:
Ohiotinkerer
Post by Ohiotinkerer »
I did mine with the truck setting on the ground.....put a floor jack under the transmission, dropped the transmission crossmember and I can't remember for sure but I don't think I took the starter out - been 4 years ago and getting old so I don't remember as well as I used to..... :doh:
1997 Honda CBR 900RR
sparky72
Post by sparky72 »
I believe you should be able to get it in there by removing the transmission crossmember alone and leaving the starter in.
Taylor
1972 F250 Ranger XLT 2wd / 8100 GVW / 390 / T18 / 3.73 D60
ajboots4
Post by ajboots4 »
Thanks all. It’s happening as soon as the rain stops.
bellamor
Post by bellamor »
https://www.americanmuscle.com/flowmast ... 18464.html
I hope that this article can somehow help you with installing the exhaust pipe.
wjwolfe82
Post by wjwolfe82 »
I know this is a few months old but I'm trying to do the same....remove/replace the Y-pipe.
Hoping the OP sees this. Though I have a manual transmission...Was removing the trans crossmember the way to go?
'69 F250 Camper Special
