is there such thing in later models fords? i have a 429 c6, and i'm not sure i want to cut a hole in my floor for an aftermarket shifter. I'm looking for a steering colum with and auto shift and no power steering.. is that possible?
thanks
kyle
c6 steering column?
c6 steering column?
kyle
1971 F100 2wd swb 429 C6
re: c6 steering column?
If you can't find one, you can easily 'build' one by simply using a manual-steering steering column shaft. Any shaft clear back to '67 (and maybe '65) will fit right into the later column housing...it'll just extend out the bottom of the column housing a few extra inches.
how does the shift selection on a c6 layout? P R D.. then what? i guess what im asking is what kind of manual would i need to make it work?
kyle
kyle
kyle
