steering column rebuild
dotcentral
Post by dotcentral »
I thought there was a tech article on rebuilding a steering column. Am I missing it, is it under a different name?
I have an auto column, no shaft, no turn signal arm, no shifter arm. Probably be better off finding one complete, but was curious what it would take to get it up to snuff.
re: steering column rebuild
Well, I don't have one per-se on rebuilding, but there is a semi-tutorial on what would be necessary to shorten a manual-steering column so it could be used with a Saginaw box. There are lots of close-up pictures for the visual:
How to Shorten Your Manual-Steering Column
390Nut
Post by 390Nut »
Ok, so one question. Just which parts store did you find those electrical connector tools at? I'm a natural born tool hound, always looking for new tools where ever I go, and I've never seen anything like them anywhere? :?
Might just have to send you some cash and a "stamped envelope" ! :D
Paul
`69 F100 390 4spd driver
I just went to my local auto store, and they had those in the electrical section, next to all the various wires and connectors.
spartman
Post by spartman »
I just used a long set of needle nose pliers to squeeze the pins.
Worked for me.
