Signal doesn't work, Flashers do
idahiboy
Post by idahiboy »
I re-wired/installed new wiring kit harness. The system works flawlessly, expect for REAR PASSENGER BLINKER.
The flashers work, and taillights work when lights/headlights on are
Doublechecked all fuses and all fuses are working
Why would the flashers work, but the signal/blinker, not?
What did I do wrong?
See below chart
BIinker
Driver Front +
Driver Rear +
Passenger Front +
Passeger Rear - Does not blink
Flashers
Driver Front +
Driver Rear +
Passenger Front +
Passeger Rear + (works when flashers on)
Any advice?
Thanks!
1968 F250 FE 390
cep62
Re: Signal doesn't work, Flashers do
Post by cep62 »
Does your right brake light work ?
I'd look in or around the turn signal switch.
idahiboy
Post by idahiboy »
cep62 wrote:Does your right brake light work ?
The brake lights work. The right/passenger back up light does not.... Notice sure if that is related.
Unless anyone else has ideas I guess I will need to pull the turn signal harness/switch from steering wheel and test or just replace
1968 F250 FE 390
cep62
Post by cep62 »
idahiboy wrote: The right/passenger back up light does not...
Just for grins , make sure you have a good ground to the light.
I like to use a long jumper wire to the battery ground to make sure.
The power from the brake switch goes up the steering column , through the t s switch , then to the brake lights.
pull the t s lever with your foot on the brake and the light should go out.
If it does , I would pull the wheel and clean the switch with electronic cleaner and see what it looks like in there.
idahiboy
Post by idahiboy »
Thanks for the information..... That is good advice..... Will try it this next week, will probably just need to pull turn signal regardless and troubleshoot.
Thanks again
1968 F250 FE 390
idahiboy
Post by idahiboy »
UPDATE
it was a bad signal switch.... Tried to clean it up and see what the issue was but 50+ yr old brittle wires just wasn't worth it, so put in new one.
All good now!
Thanks people for suggestions
1968 F250 FE 390
