Surging electrical
Tingalls
Surging electrical
Post by Tingalls »
I recently purchased a 1973 F250 camper special.
When driving at night my headlights and interior lights are surging.. bright..dim.
Does anyone know how to fix that?
I was going through the electrical and wondering if the ballast resistor could be the problem?
tsherry
Re: Surging electrical
Post by tsherry »
I had a couple issues with similar symptoms: 1) Voltage regulator was tired; 2) wiring and a series of bad grounds.
In the end though, I ended up replacing the original alternator for a 3G, and converting the headlights to a relay system.
too many Fords, no where near 'nuff time.
or, money.
Tingalls
Post by Tingalls »
How do I attach a picture?
Tingalls wrote:How do I attach a picture?
You can either host it some where online and then link it using img tags, or if it is a small enough file size you can attach it directly in the reply window by using the tab “attachments" below the reply window (next to “options”) and check the box that says “place inline” or something like that.
basketcase0302
Post by basketcase0302 »
sargentrs
Post by sargentrs »
DuckRyder wrote:..or if it is a small enough file size you can attach it directly in the reply window by using the tab “attachments" below the reply window (next to “options”)...
That's what I typically do. https://fordification.com/forum/viewtop ... 569200cb08
If it's too big I edit the photo in Paint, resize to 800x600 pixels and save as a .jpeg file. Usually gets it down under 500kb.
Note: Looks like it's changed a little since I wrote that. I can't believe it's been 7 years! Where did they go....?
