'67 F100 352 header recommendations
JHof44
Post by JHof44 »
I'm sure this has been covered to death, but I'm not having much luck finding an answer. I have a '67 F100 2wd with a 352 that has a good leak from the drivers side exhaust manifold and I've decided to pull the trigger on a set of headers. Engine is stock other than a Holley 2bbl 350cfm carb. I don't plan do the intake manifold or 4 bbl for at least a couple years since this carb was new a year ago and the truck runs good enough for me.
So, what headers would you guys recommend for my setup? Not concerned about price, just want the best quality and fit. Any info is much appreciated.
-Josh
1967 Ford F100 Custom Cab longbed
colnago
Re: '67 F100 352 header recommendations
Post by colnago »
I plan to use Sanderson Shorties on my '67 352. I don't remember the part number (FF327?), but you should be able to search on the forum, or on the Sanderson site. Most guys don't use the full-length headers, because there's too much interference.
Joseph
Godspeed128
Post by Godspeed128 »
Check out my topic this is what I used and links to headers
http://www.fordification.com/forum/view ... 17#p750717
RangerRat
Post by RangerRat »
Love my Sanderson shorties
JHof44
Post by JHof44 »
I ended up ordering the Sanderson's a couple weeks ago, just waiting on them now as they had to do the ceramic coating. I appreciate all the input.
geradr4
Post by geradr4 »
How's the fitment of Sanderson shorties? I'm planning to buy one.
JHof44
Post by JHof44 »
geradr4 wrote:How's the fitment of Sanderson shorties? I'm planning to buy one.
They fit perfect, really high quality product. I ended up going with a mini starter at the same time but I've heard varying reports that the stock starter may fit with them.
