![Image](https://farm2.staticflickr.com/1759/42648836162_b525e5585c_k_d.jpg)
![Image](https://farm2.staticflickr.com/1726/42648826792_49b785dd81_k_d.jpg)
If you're not a welder now , you will be when you get done.North56 wrote:I am just learning to weld.
Jacksdad wrote:A new cab would absolutely get you on the road a lot quicker, but I've repaired worse. My dear old dad's shop was in the north of England, and we got a reputation for working on old/oddball stuff that it wasn't always possible to buy repair panels for, so we made new ones from scratch using cardboard templates. That said, you still need to factor in damage like roof rust. That is not an easy fix.
Just for context, the climate in Britain is perfect for rust like yours. I wouldn't be able to do half the things I can if it wasn't for projects like this. If you have the time, and a long term spot to park it, it's fixable. Nothing ventured...
Like I said, it depends what your priorities are. On the plus side, either way the truck gets fixed
So that would be the Mig Pak 140 ?Must have gas. Run .023" wire on a 120 volt machine because it'll run hotter with less amps as well as run colder on thin stuff. Floors qualify as thin stuff.
