Hole in firewall...?
- Bullitt74
Steve F.
Red Deer, Alberta, Canada
'72 Ranger XLT, 4x2, 390-2V, C6, Wind blue & Wimbledon White (‘Smokey’)
2016 F150 Lariat FX4 Supercrew, Ruby Red
Follow my build thread for 'Smokey': http://fordification.com/forum/viewtopi ... 22&t=85070
Re: Hole in firewall...?
For your speedometer cable.
- Bullitt74
Hmm, my speedo cable comes through another hole just to the right of that one:
Looks like it has a fairly robust grommet as well, so not sure if I can move it without damaging the grommet.
Thoughts?
Thoughts?
Steve F.
- DuckRyder
My speedometer cable comes through your open one. Has a foam gasket much like the one on the heater cable...
- Bullitt74
I wonder if my body man routed the speedo cable through the wrong hole? Seems like more of a straight shot to the cluster to route it through the hole that is open. If that is the case, I wonder what is meant to route through the hole that my speedo cable currently goes through?
Steve F.
- DuckRyder
I’m having trouble locating the one your speedo cable goes through.... picture from firewall side?
- Bullitt74
Sorry - the second pic was from inside the cab,
Steve F.
- Ranchero50
I'd lay money that's where the heater temp cable comes through.Bullitt74 wrote:I wonder if my body man routed the speedo cable through the wrong hole? Seems like more of a straight shot to the cluster to route it through the hole that is open. If that is the case, I wonder what is meant to route through the hole that my speedo cable currently goes through?
- DuckRyder
Heater cable goes through over the passenger side valve cover. 2 Wiring harnesses over the driver side valve cover speedo cable over booster in the vacant hole in the first picture. Another wiring harness over the near the hood hinge.
- Bullitt74
Thanks Robert! Going to rejig these around a bit. Sounds like I didn’t need to drill a hole in my firewall earlier for some add ons...
Steve F.
- DuckRyder
See if this helps:
Pardon the filth, gotta clean it up...
- Bullitt74
Steve F.
