Light switch
jzjames
Light switch
Post by jzjames »
Can anyone confirm if the light switch on the dash is the same for all years 67 thru 72?
I can't remember if it's the light switch or the ignition switch that is a 67 one-year only.
MadMike
Re: Light switch
Post by MadMike »
Ignition switch changed several times over the 67-72 years. '67 is one, mid year '70 it changed again.
AFAIK the light switch is the same from the mid 60s to the mid 80s.
Check rockauto, they are pretty good at noting differences via the serial numbers.
-Michael
jzjames
Re: Light switch
Post by jzjames »
Thanks madmike. Wow, amazing a lot of these parts are still available. Ordered one off Rockauto.
