Bolt pattern for 1967 F100
I want to buy new rims for my truck, I am keeping the original stance of the truck but want a good set of rims and tires. what is the biggest rim I can run for the sport look 17", 18"?? X8,9"? What is the bolt pattern. nobody in this area seems to know, not even the local tire stores. Please help......
- Thundercat6870
re: Bolt pattern for 1967 F100
Your bolt pattern is 5 X 5.5" for most full size ford and dodge trucks. I've seen all kinds of huge rims for them but you have to make sure the backspacing is right.
MADD MODDS Custom Restification & Fabrication
Two 68 F-100 SHB's one 4X4
68 Cougar XR-7
Three 70 Cougars, Two Xr-7's and one Eliminator clone
68 Thunderbird suicide doors W/factory console
87 Thunderbird 289 H.O. MassAir T-5
68 Cougar XR-7
Like thundercat said, 5x5.5 or metric 5x139.7. For the front I would most likely want to try to use an 8in wide rim with about 4in's of offset. For the back you could probably do a 9in wide rim with the same offset. Don't use this as scripture but from my experience it should work. Best thing to do is take your wheels off and do lots of measuring before you buy anything.
MOSES
MOSES
1968 f100 Ranger
1972 f100 Sport Custom
1972 f250 4x4 conversion
- mrung0wa
With stock suspension you don't want to go with a rim any wider than 8 1/2" or the tires that you put on will rub!
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
- CJ,s 67 F100
5x5.5 and on a 8 in. wheel get 0 offset and 4 in. back space
